A little oil is not unusual, tough you should keep an eye on it.
A good guide to the state of your AOS is try taking off the oil filler cap (in the rear boot) while the engine is idling. If the cap is difficult to remove because of a vacuum, then the AOS is failing and a new one required.
2001 MV Agusta F4.
