Old 05-07-2010, 08:49 AM   #11
Oaktown 986
Originally Posted by Lucky
Based on what you've shared so far regarding the failure (just stopped, no unusual noises, etc.) and your attempts to diagnose, my best guess is the crank position sensor (CPS) has gone bad. As a result the engine computer has no idea where TDC is for each cylinder and can't determine when to fire the spark plug.
The only other reasonable possibility is a huge vacuum leak. One of the AOS hoses could have come loose or some other hose of a similarly large size. Check everything that connects to the intake system -- both ends of each hose and the hoses themselves for splits/cracks.
It is unlikely that the coil packs are bad. All 6 don't fail at once.
Thank you; this post has given purpose to my weekend: shall report tomorrow on findings for the AOS or any other hoses that are split, cracked, or disco'd.
Jonny Wonder
1999 Porsche Boxster 5 Spd
Stock, with GAHH A5 Glass top.
Previous Toys:
2005 RX-8, RIP
1989 GTA, 5 Speed, Procharger Supercharger and 2 Core Intercooler, 1 3/4" headers, 3" Flomaster Exhaust, cat-delete, digital ignition, bigger fuel injectors
Oaktown 986 is offline   Reply With Quote
