Thread: DTC's
Old 05-06-2010, 02:36 PM   #3
extanker
Originally Posted by sheep
Hi Randall ty , no ive not taken offence i also should off added lol , yep i havent used the car since , it first illuminated 4-6 weeks ago so i plugged it in with the engine off and after using several different softwares got a return of no stored or pending codes , so i started the car and ran it with the OBD2 attached , up to normal running temp (approx 85) and then turned off and again while running and off i got no codes or concerns of any issues with the car , it was then only yesterday as i pulled up to my garage door that it started flashing so i quickly plugged it into the pc in the garage and managed to get the DTC's , the light had actually gone out again and everything was normal.
Once i got the codes i turned the car off and then just the ignition back on to be met with no mil light or stored or pending codes i didnt even do a clear so i am assuming that its an intermitant fault and that it could be either a dirty wire or a sensor is starting to go down the pan.
many thnx for your reply
sean
wait til they catch ya spellin bad.....the cuties want to spank ya
extanker is offline   Reply With Quote
