Thread: DTC's
Old 05-06-2010, 09:04 AM   #1
sheep
Hi Randall ty , no ive not taken offence i also should off added lol , yep i havent used the car since , it first illuminated 4-6 weeks ago so i plugged it in with the engine off and after using several different softwares got a return of no stored or pending codes , so i started the car and ran it with the OBD2 attached , up to normal running temp (approx 85) and then turned off and again while running and off i got no codes or concerns of any issues with the car , it was then only yesterday as i pulled up to my garage door that it started flashing so i quickly plugged it into the pc in the garage and managed to get the DTC's , the light had actually gone out again and everything was normal.
Once i got the codes i turned the car off and then just the ignition back on to be met with no mil light or stored or pending codes i didnt even do a clear so i am assuming that its an intermitant fault and that it could be either a dirty wire or a sensor is starting to go down the pan.
many thnx for your reply
sean
sheep is offline   Reply With Quote
