Lift up the carpet in the rear trunk and see if there is water underneath it. The carpet itself may not be wet because there is a cardboard panel underneath it. If its wet there the bottle is leaking.
If you undo the nuts that hold the bottle in sometimes you can pull it out enough to get to the hose clamps. Also replace all the hoses while you are in there otherwise you will be doing it again.
chris
