Thread: Transmission
Old 04-29-2010, 06:15 PM   #12
Lil bastard
Lil bastard's Avatar
Originally Posted by jcb986
I thought you where suppose run the engine for awhile to heat up it to a certain temperature then add more until it runs out, then quickly run it thru P, D, P, D then top it off.
Well you're correct.
But the temp range given for a proper fill is pretty narrow. It takes a while for the temp to rise, but then, it goes up like a rocket. You cannot let the temp creep higher than the given range and still get an accurate fill either.
That's why I propose pre-heating the fluid, especially for a 1-man job. Once that tranny starts to pressurize, excess fluid will just pour out. If you're jumping from the car to get back underneath and add more, it's almost a losing battle, not to mention the expensive fluid you end up wasting. If you have a helper, it's much easier to do it the way you describe.
Even pre-heating the fluid, I lost more than a half litre while I was ratcheting the selector.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
