Yes, it should be able to be done. But you will need to fool the immobilizer feature into thinking that a key is in the ignition. Here's what I would do: open the electronics portion of your car key. Remove the RFID 'pill', and fix it up under the dash very near where the ignition key goes. The rest of the remote start install should be standard like any other car.
Of course, you have essentially disabled a security feature of your car in doing this, as any key that can turn the ignition will start the car. But on the bright side, key programming is no longer necessary.
Demick
'04 Boxster S
