Old 04-27-2010, 07:00 AM   #12
BikerDrew
Good luck with your project.
Be sure to notice where the two long mounting bolts came from so you can put them back in the same places. The inboard ( hard to reach) bolt is one of them. you will need a 10 mm wrench and a 10mm socket which for me was easier with 1/4 " drive tools. I ordered a metal gasket and had no luck sealing it given the low torque of the fasteners. Maybe it was the temperature outside, but it would not hold presure for me.
BE SURE to bleed ALL the air out of the coolant system. I am sure you can find a thread on that issue. I was easy for my project, so don't worry about it.
BikerDrew is offline   Reply With Quote
