Old 04-21-2010, 04:59 PM   #1
jcb986
jcb986's Avatar
"Tires were not the problem. Front passenger side tire still vibrates when hot at low speeds (5-20mph). Now the front brake seems to have a loud metallic squeal that only occurs only when the car is hot. Brakes are only 6 months old. Brakes are always quiet on cool days (<75 degrees).
Obviously something is going in the front. Any ideas how to troubleshoot? I may need to take it to the mechanic when it is hot."
Originally Posted by m208334
Tires are subject to going bad...the belts can begin to separate and you will need see it. One way to trouble shoot it is to swap tires and see if the problem moves to the other wheel. As for the squeal, I would think something like a wheel bearing going bad but if the squeal only happens when compress the brakes, it most likely the pads. Cheap metallic pads are to me a no no...they will feel good but once they start to wear you can get a squeal. Good pads on a Porsche are semi-metallic compound, yes , more dust.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
