Old 04-18-2010, 06:39 AM   #2
sheep
Hi Suburban
yep did this and the micro switch seems to work fine but the handle doesnt seem to travel all the way back to the stop position thus pushing the microswitch back to its intended position, if i press on the handle it moves about 2mm and you hear the microswitch click and the window returns to where it should be.
i was wondering if there was any adjustment that pulls the cable tighter as it seems like the cable is not pulling the handle back to its stop postion , i did hear there was a spring in there that gets worn and upon inspection can find no spring or a location where a spring would go ??
mny thnx for your reply
sheep is offline   Reply With Quote
