Originally Posted by eightsandaces
Just for the hell of it you should check every spark plug torque, it solved my strange noise and two were loose.
Problem is, it starts after the engine has been running for over 20 minutes. The spark plugs chirp when loose not squeal to high heaven. Thanks for the input...I had replaced a few tubes not more than 200 miles ago so I know the spark plugs are tight.
