Old 04-16-2010, 07:31 AM   #1
Topless
Track rat
Topless's Avatar
Originally Posted by jmatta
You can spend thousands and only gain minimal HP the factory left as headroom...the only way you'll see appreciable gains are in increasing displacement. Any forced induction system will greatly reduce the life of already questionable internal components.
Visit our sponsor, www.flat6innovations.com for more information.
+1
A properly installed turbo kit is about $10K and if you push the motor hard you will need another one of those shortly when it grenades at around $15K. The factory 986 was simply not designed to work well with FI. With enough money anything can be done, but does it make sense on a fairly light weight, high compression motor?
Suggestion:
Learn to use all of your car first. A 3.2L Box S is a formidable track weapon in the hands of a skilled driver. The Boxster Spec racers are already turning lap times that rival 996 Turbos and GT3s at the track and they are running bone stock 2.5L pea shooters (stock intake, stock headers, stock internals). If after a year of DEs you still need more HP just drop in a 3.6L.
