If your CEL error codes are still P1128 & P1130 your car is still running lean. This means a failed MAF or intake air leak. A hissing sound points to an intake air leak as the most likely cause for your problem. If your mechanic does not recognize this or believes that changing spark plugs will somehow resolve a lean mixture condition... get a new Porsche mechanic.
Troubleshooting and diagnosis requires the simple process of elimination. List all the possible causes, one by one eliminate each starting with the most likely cause. This works every time.
1. Bad MAF- unplug your MAF and drive the car. If it runs much better, replace the MAF.
2. Torn intake hoses- inspect one by one and replace as needed.
3. Loose hose clamps- inspect and tighten.
4. Torn AOS Bellows- replace
5. Cracked oil fill tube- replace
6. Bad gas cap- replace
And so on and so on.
If it were my car I would begin by opening up the engine cover, start the car and just listen/poke around for the hissing sound. Some will use propane to identify an intake air leak but I totally singed my eyebrows once with a propane flash fire so I am not a big fan of this method. Maybe just a loose hose clamp. No reason to get hosed with unnecessary repair charges.
Get your error codes first to confirm the problem and then proceed. Good luck!
