Thread: Caliper Bolt
Old 04-12-2010, 04:17 PM   #8
RandallNeighbour
The tips on the top front caliper bolts are exposed in a cup-like recess in the wheel carrier. My thinking is that they are exposed so as not to build up pressure with the anti-seize accumulating at the bottom of a hole.
Because of this situation, these can corrode due to water accumulating there. I think mine rusted because the car was in Utah for a bunch of years as a DD and the road salt probably got in there and wasn't washed out regularly.
Two years ago, some of you probably remember me moaning over the fact that both top bolts up front on my MY97 took nearly 2 hours to remove (each one!) with the same back and forth loose, tighten motion recommended earlier...and the bolts when finally removed completely sheared off the threads in the wheel carrier. It was as smooth as a machined hole.
I would imagine that this is what will happen when you finally get that bolt out of yours too.
I had to buy a time-sert kit, drill it out bigger, put in a new insert, and then put in new bolts. The brand "time sert" is like Helicoil, btw.
That was a nightmare. And an extra $200 and week at my buddy's house I had no desire to spend on my brake job.
