Old 04-03-2010, 08:14 AM   #4
jonnycool
jonnycool's Avatar
is the roof down? how did he take the fuse cover off if he can't unlock the door?
If you unlock the door with the key press the door lock button on the dash, it will be red until you push it but then mine is a UK car so it could be different?
You really should have a button on your key, this is the remote, your battery may be flat in it so check your owners manual to see how to change the battery in your key if this is the problem.
jonnycool is offline   Reply With Quote
