Old 03-29-2010, 08:01 PM   #1
wulfgang
You had a shop do this. They should fix it for you. If not, here are two ideas:
1. Park it out in the sun for a few days with the top up.
2. If that does not work, then you can adjust it just a bit in the back. To do the adjustment, put the top in the service position. Down by where the back cables connect to the car, you will see a block with a bolt (1 on each side). Counterclockwise reduces tension, allowing the top to sort of tip forward a bit more, which should allow you to close it. However, this of course affects other things as well...
wulfgang is offline   Reply With Quote
