Originally Posted by ARModen
Check the filter for leaks with the car running. Having the ignition in the ON position does not turn on the fuel pump. The pump only comes on when the engine is cranking or running for safety reasons.
yeah i did, no leaking / seepage. the connections were dry and no gas smells. also the under panel was dry ( dusty even ) and had no gas smell. probably all in my imagination or the computer needs a little time to adjust to a clean filter - like i said the original filter was on there @ 72k miles.
i'll keep track of the mpg and worry about it later if it's still a problem. thanks for the help guys.
