Old 03-21-2010, 02:00 PM   #4
Steve Tinker
Steve Tinker's Avatar
Have you checked if there is a fuel leak around the filters snap on connectors. It doesn't need much of a weep while driving to blow out your fuel usage - remember it will only leak when the engine (or ignition) is on or running.
So to confirm a leak, you will have to get under the car with the ignition in the "on" position to pressure up the system.
2001 MV Agusta F4.
