Old 03-15-2010, 07:29 AM   #1
schoir
Originally Posted by smeech
I panicked! Urgently needed to get car started and went a bit loopy.
Strangely enough I am 6'2". I am buying a new battery. Is it worth buying that first and trying to start and seeing if that sorts out the ignition switch or do you think it is definitely gone?
The car will still probably start with the failing switch.
However, from what you have described regarding the ignition switch, and because the ignition switches fail and fail often on Boxsters (and other Porsches), I'd say you should replace the switch. If you buy the Audi part number and DIY it's only around $10.
The Audi Part Number, a/k/a/ the "new and improved" part....4A0-905-849-B, recognized as the replacement ignition switch part of choice for 986's and 996's.
Regards, Maurice.
schoir is offline   Reply With Quote
