Originally Posted by rick3000
Thanks!
And should I be worried about the heated up and bent right toe arm?
If it's steel then I think you should be ok, but if its aluminum I would replace it. I'm not sure what material it's made out of though so maybe someone else on here can volunteer that info. The safe bet would be to replace it and that's probably what most people would recommend. Maybe have them put it back up on the lift so you can see for yourself and go from there?
