Old 03-09-2010, 06:28 PM   #11
Adam
Rick, your specs look pretty decent. Typically for a good handling street setup you want 0 toe up front, very slight toe in on the rear and a little negative camber. All the specs there reflect that and are close. I have more negative camber dialed in up front and less toe in at the rear but I use the car a lot for autocrossing. Your car's specs look good for normal street use.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
