+1 on what LB says - whatever made you think connecting a battery charger would help start the car?? The starter motor pulls over 100 amps turning over the engine while a charger delivers less than 10 amps......
As to removing the key, sometimes the springs in the lock get worn (a heavy bunch of keys on your fob don't help) so a new ignition switch may be required. Its not a difficult job as long as you're not 6'2" tall, as you have to get under the steering wheel to install.
2001 MV Agusta F4.
