Ignition (starter) switch is Kaput. Cheap, easy fix.
NEVER try to start the car with a battery charger hooked up to it!
That is unless you actually enjoy shelling out thousands of dollars (£'s in your case) to replace fried electronics!
If you need to recharge the battery, recharge it and wait. If you make you electronics go Blooey, you'll wish you had.
Cheers!
