Old 03-08-2010, 09:34 AM   #2
Rdward
I thought the plugs were supposed to be installed dry? The sealant I used for the cover was from Sunset and it's what they suggested I use. I did try sealant on the plug(after about six dry runs with it just blowing the plug out) just to see if it would hold. It lasted about 2 minutes and then the oil pressure forced it back out.
Is there any way that oil can get in, but I clogged up the way it goes out with to much sealant? I also was thinking that the plug could be defective and a little smaller than spec.
Rdward is offline   Reply With Quote
