Old 03-08-2010, 08:38 AM   #5
schoir
Originally Posted by willd
Hey all
- And then my second problem. Before I abandoned the car for the winter (i.e. before I started my own mould farm), the roof got stuck. I had to disconnect everything and it's been a manual effort ever since.
I've checked the switch which lies at the back of the soft-top, a lever like affair, seems ok. The switch in the dash is ok too. Now seeing as there are two motors (I am correct in that I assume?) I'm assuming one would work whilst one didn't, fi one had died.
The relays are all fine, the fuses are all fine.......
Any ideas on the above?
Thanks!!
There is only one electric motor that drives both top transmissions. It's located directly under the "lever-like affair".
Here is a link that should help you resolve any of your convertible top problems:
http://sites.google.com/site/mikefocke2/thetop-itsmaintaince%26replacement
Regards, Maurice.
schoir is offline   Reply With Quote
