Old 03-03-2010, 06:15 AM   #2
vipola
Put your jack on a Corner.. Jack the car the higher you can, go put Candle at other point, repeat until you have 3 candle installed.. most of the time you'll be able to slide in the 4th candle without the jack because the car will already be supported at the 3 other place
You may also want to jack the car at a front/rear center point to be able to pu two candle at the time..
vipola is offline   Reply With Quote
