Old 03-02-2010, 07:11 PM   #13
jhandy
Also I suppose if you are going to do the belt and the Coolent, You might as well put a new water pump in and low temp thermo.
It would be a shame to be driving with 70K on the clock and the plastic waterpump blow out. Then you need to add 150$ to the repair for the fluids anyway. (not to mention the wasted fluid you just put in).
2002 S
jhandy is offline   Reply With Quote
