Old 06-19-2005, 11:29 AM   #4
Lux
limon and Tech,
Maybe you guys just didn't notice the swirls before? Regardless, they are now there and there's only one way to get rid of them. And that is to polish them out.
I believe the Meg's paint cleaner is a cutter. You need to follow up with a true polish before waxing. And you might have to go over the same area a few times. All Waxing does is provide a protection layer.
Lastly, maybe your cars didn't need the aggressiveness of the Meg's paint cleaner and you simply used the wrong product (which would explain seeing new swirls...but not if they don't match your buffing/removal motions).
It will be next to impossible to remove swirls by hand. A rotary (dangerous to use for a novice) or a PC (fairly safe for a novice) will be needed. You can either get a PC and try your hand at it or take it to a professional.
Lux is offline   Reply With Quote
