the cyclo is probably the best in terms of speed of results and ease of use.
I use the PC which is not as good but not as expensive either. At setting 5 for de-swirling it produces a great deal of vibration which might make your forearms numb since you have to move very slowly in overlapping L patterns. on the hood and other horizontal surfaces its not as bad because you let it settle on its own weight. and by the way ALWAYS hold the pc by the handle, its heavy and will dent your car easy if you drop it. also, you'lll need the velcro backing plate (if you don't buy the new xp) which doesn't come with the unit and white and yello pads. white for cleaning, yellow for cutting. grey pads are for waxing.
p.s.
I picked up a portable Bissel steamer at Costco for about $60 which does a decent job for cleaning matts and carpeting. its called the gre en cleaner or something. I bought it for the house but it does the job in the boxster.
BORN: March 2000 - FINLAND
