Old 02-24-2010, 06:56 AM   #8
Aron in Toronto
Originally Posted by Pirrex
I did that already, but it would be nice to get everything in metric units. It's not possible to switch the temp on the OBC to celsius, is it?
To switch the temp readout press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius & Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays.
This method worked on my 1997 model. It bay be different for later years.
IIRC Models after 2000 may require the setting to be changed by a dealer with the PST-II
http://forums.rennlist.com/rennforums/996-forum/348985-change-mph-to-kmh-how.html
1997 Boxster
http://i40.tinypic.com/ax1qhz.jpg
Aron in Toronto is offline   Reply With Quote
