Old 02-17-2010, 12:24 PM   #26
root_werks
root_werks's Avatar
With my Box having 103k on the clock and pretty much everything original, I plan to replace the following which will hopefully resolve the latest CEL:
993-113-250-03 - Crank case check-vent valve
996-113-245-01 - Change over vavle for air injection
993-113-245-01 - Cut off valve for air injection
All those will be around $200 and if they don't solve it:
996-605-201-01 - Purge vavle for fuel vapor canistor
And if I get desperate:
996-606-160-01 - Idle air control valve - like $300 or so.
The change over valve has an electrical connection on it, so I am hoping that is what is causing the CEL. We'll see. I'll post back results here.
Before I order anything though, I'm going to pull the lid this weekend and check hoses again, make sure things are clear and actually see if I have any of the above listed EGR related parts on my Box. It's a 97', so I can see Porsche using some 993 parts I guess?
Making progress!
root_werks is offline   Reply With Quote
