Old 02-12-2010, 05:30 AM   #2
eightsandaces
OK I'll bite.... If you're going to change the headlamps, save up and get the litronics, the clear lenses are only a half step cheapest new items are likely at Suncoast Porsche. Make sure you handle the little triangles with great care, the attachments are far from robust. As for the inside plastic bits, the cheapest solution would to be patient and locate a wreck or car being parted out, occasionally there are such cars in the parts section of this blog, good luck..
eightsandaces is offline   Reply With Quote
