Installed the raby under-drive pulley
I was avoiding this mod because i did not feel like messing with the trimming of the case.
Then I saw a commerical for the dremel multi-max. It is a flush cutting tool.
I got the pulley and belt from Jake, The nut from dealer, Incedently you can not get a new thrust washer. Has to be ordered from germany and for some reason hard to get.
Anyway. the dremel thing sliced throught the caseing like butter, took less than 1 min.
Total install- @45 mins.
Drove it and I am very impressed, there is a very noticeable increase in power. More than I have got from any other bolt on.
Alt voltage holding at 14.3volts.
I vote this the best mod ever!!
2002 S
