Old 02-05-2010, 09:46 AM   #1
Lil bastard
Lil bastard's Avatar
Originally Posted by Mark_T
OBD, OBC, DME, PST2, PIWIS, egas .... Fellas....I'm just a simple cableguy and this is all going right over my head. Plus, I've only had the car for a few months and I'm still at the steep end of the learning curve.
Let me see if I'm understanding this or not:
Because I have a '99 without egas I will need to get the control unit (kindly offered by Todd) and I will also need to acquire the cruise stalk for the steering column, but the wiring should already be in place (or not?). Does this mean that I if I get these two components they should plug right in to existing plugs/ports/wires and then all I would have to do is go down to the dealer to get the cruise "turned on"?
Mark
Almost - you also need the disconnect switches for the brake and clutch (assuming a manual), then you're good to go.
BTW, this should help flatten your learning curve: OBD = On Board Diagnostics (OBDII on the Boxster), OBC = On Board Computer, DME = Digital Motor Electronics (ECU), PST2 = Porsche Systems Tester #2, PIWIS = Porsche Integrated Workshop Information System (really just a proprietary version of Bosch KTS650), egas = Electromechanical throttle control - Drive-by-Wire - 2000MY+.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
