Old 01-25-2010, 01:52 PM   #5
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by Viper5
This is what I'm talking about:
http://boxsters.addr.com/hacks/volume_control.htm
I called the number listed but it doesn't seem to be available anymore.
Normally, this feature is already built into your radio unit, and you can just adjust the level from 1-7 on the GAL feature in the radio menu. Just look it up in your radio manual, and it will tell you how to set it. It works fine in my car...almost too good, as when I get past 40mph, it gives a bit too much volume boost, and I have to pipe it down a bit manually. Not sure why the feature didn't work in that guy's car to start with.
