Old 01-24-2010, 03:40 PM   #1
heyjae
SOLD Part Out 2000 S - Arctic Silver / Black
Parting out my track car which had about 88,000 miles. It suffered a catastrophic AOS failure which caused much engine damage. It was a dedicated track car so much of the interior was gutted and the top is gone, however there are a lot of other good parts--just ask and I'll let you know. I'll also list aftermarket components as well. Let me know if you want the entire car. I prefer local (Southern California) sales for larger items and none of the prices below include shipping. I'm happy to meet people halfway to deliver larger items/sales.
Partial list of major items (there's a lot, so please forgive errors in pricing and description):
6 speed manual transmission - was replaced with a reman unit under warranty by Porsche at 45k miles and has been working great since. $1,000
BBS LM 18 x 7 and 18 x 8.5 w/ Nitto NT01 (235/40 and 275/40 I think-need to double check) - tires have only 1 track day and 4 heat cycles (barely since the motor blew on my 4th run). Used on the track, so has scratches and nicks, but is straight and true. $1,500
JIC Magic coilovers - about 2 years old with about a year of use and less than 5,000 miles. Springs are stiff at about 500 lbs and 600 lbs. I'll update with exact specs. $850
GT3 front sway bar - bought used from another track junkie. $120
H&R rear sway bar - bought used as well. $100
Mantis rear understrut brace - bought used as well. $75
NHP Headers w/ 200 cell cats - The O2 sensor bung is cracked and a simple weld should fix it (explains the mysterious MIL codes I was getting). $300
Fabspeed Rear Cat bypass pipes - I still don't understand why these things are so expensive but they are. I bought them new for $450+. $300
Cheap Chinese muffler - the plates between the exhaust pipes are broken, but otherwise ok. $80
Crappy carbon fiber hardtop - seriously bad carbon fiber. I drilled holes to bolt it to the cage. Ugly. Did I mention bad? But light. $150
Crappy carbon fiber hood - an eBay cheapie, but light. Holes drilled for hood pins, doesn't fit very well, but light. $80
Crappy-ish carbon fiber front bumper - a few cracks and I attached some canards on it. Fit is tight and required lots of modification. Not much lighter than the stock but is molded to GT3 look. $200
Ok carbon fiber mirror covers - fit is tight (see a pattern of bad CF?), but looks pretty good. $120
Good carbon fiber side intakes - looks good, fits pretty good. $100
Bolt in 6 point cage - bought it used, fits under OEM soft top. I'm not 100% it fits under the OEM hard top (might require some plastic trim modifications). $250
3 spoke steering wheel w/ silver crest, airbag. the crest does have some scratches (it is 10 years old afterall), but in pretty decent condition. $700
APR carbon fiber rear wing attached to my arctic silver rear trunk lid. $200
Underdrive pulley. $140
EVO Cold air intake. $200
Various wheel spacers. 5mm, 8mm and 10 mm and longer bolts as needed. Ask for price if interested.
I'll add more items and details/changes as I remember it.
2000 Boxster S
http://www.slipangle.com/images/ACSpeed_sig.jpg
heyjae is offline   Reply With Quote
