Originally Posted by rick3000
If it's a 2000 you don't really need to worry, IMS only affects post-01 cars. I don't even think Raby's retrofit will work on a pre-01 car since the redesigned IMS is what caused a the problem.
Absolutely incorrect.
The IMS syndrome is clearly an issue with ALL models and years of the M96, including pre-01 models.
The IMSR procedure and bearing is applicable to all M96 engines from 1997-2005.
US Patent 8,992,089 &
US Patent 9,416,697
