Old 01-19-2010, 06:28 AM   #2
ppbon
ppbon's Avatar
Originally Posted by Burg Boxster
in a pinch, you can bypass the clutch micro-switch by shorting it using a jump wire between the connectors on the rear. Just make sure you still have the clutch engaged or the car in neutral when you go to start it.
In a pinch?
That's been one of my permanent hacks since I bought the car.
It's very useful when tinkering, to just reach in through the open window and start her up.
Also, when I live in MO, in the winter, when it was below zero, I'd start the car without having to sit on the cold, cold seats.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
