01-06-2010, 10:02 AM
#5
Failure Mods
Originally Posted by stephen wilson
I'm gad to hear you're keeping the car, and if the IMS bearing upgrade lets you relax and enjoy it, it's well worth it.
I believe the other failure modes require more engine disassembly, off the top of my head : timing chain tensioners, lifters (not catastrophic), C-chuck failures ( rare except for '99 or so ) , oil pump drive ( very rare, only racing? ), rod bolts ( very rare-racing? ), oil starvation under racing conditions ( only with racing tires? ), cracked heads ( rare ) , heat exchanger leaking water into oil ( rare ), water pump failure-broken shaft.
I believe you have a Tip, so no clutch issues?
YEs I have a tiptronic transmission, my car runs fine just bad air oil sep and some vacum leacks, valve cover and RMS leaks i am doing all that thi weekend and the bearing!!!!!! hopefully my cylinder walls wont crack
