as for the tires, they will look fine on 90% of the tread. Look for the inside wear in a strip of about 1 inch. the outside of my wheels had great rubber, but the inside was showing belt.
It might be because I have a factory M030 setup, and the car rides a little low from the start. The lower you go, the more screwed up it gets without a longer tie rod.
It is just impossiable not to happen. Stick your head under the rear of the car and you will quickly understand why. you cant change one without the other.
2002 S
