Old 12-18-2009, 07:50 AM   #1
Bladecutter
Originally Posted by ocoeeboxster
I have 17in factory option wheels not sure what the mm
Well, go grab a piece of paper, a pen, and walk over to where your Boxster is, and write down the numbers that are on each side of the tire valve stem.
One number will most likely be like this:
7.5
8.5
The other number might simply be:
55
51
Write down the numbers from both the front and rear wheels, and post that info on here, and we can help you from that point.
Also, if you have the same numbers from the Cayman, that would be quite nice, also.
BC.
Its not how fast you go, or how expensive your toys are.
Its all about how big your smile is at the end of the day that truly matters.
'98 Silver Boxster, '08 Ducati 848, '89 Honda Hawk GT, '89 Honda Pacific Coast
Bladecutter is offline   Reply With Quote
