Old 12-14-2009, 02:35 PM   #1
Matt Fredrikson
Send a message via MSN to Matt Fredrikson
Light only after it has recently been to high rpm however, the first shift as I'm at high rpm is good then no matter if you stay on it and shift high again or slow down and shift low the clutch feels light. So for example, run it up to 6K in second and then shift from 3rd to 4th at 2500rpm and continue on as such the car shifts light untill it has a chance to be parked and cool down.
Again, by light I mean peddal takes no effort to push could be done by hand with ease. I would say the clutch is worn but its almost as once some power is applied and heat generated the pressure plate fingers loose there spring back. If that makes sense.
Matt Fredrikson is offline   Reply With Quote
