Old 12-02-2009, 02:07 PM   #11
Adam
Originally Posted by jacabean
Ok , I got pirelli p-zero asimmetrico tires , 225-40 front 285-30 rear 18" . the car has a set of H&R coilovers and the factory M030 package , built to Roocks specs. So if I lift the entire car a 1/2" or so how will this change the handling? I do not have the alignment specs. what do you guys think is the simplest way to adjust the car for street use. I do not track this car. just some crazy back road blasts .
At least part of your understeer problem has to do with the extra wide tires you have on the rear. You need wider tires up front as well, like a 245 to balance out the back. The Pirelli's you have are ok, but there are better street tires out there for ultimate grip. Look into Kuhmo XS, Bridgestone RE-11, or Dunlop Star Specs. On a well set up car you'd have to have a death wish to overwhelm those tires on the street.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
