Old 11-29-2009, 08:41 PM   #4
brp987
You say "you know you did it right". I don't know that. Did you use the SIR bearing installer tool from Pelican? You pulled the bearing into the hub by the outer race, right? You pulled the flange into the bearing by the inner race, right? The axle threads were clean and the nut spun freely, right? You tightened the axle nut atleast somewhat before setting the car on the ground, and definitely before rolling, right? I hope the cv's were packed w/grease and the cv bolts properly torqued. Bonus points for schnorr washers or threadlocker - those bolts can back out, leaving you stranded.
I've installed rear bearings on 911, 914, and boxster, and even one out-of-the-box bad FAG bearing is, to me, incredible - despite the name.
brp987 is offline   Reply With Quote
