Old 11-23-2009, 06:18 PM   #2
Spanky
Intermitent Starting Issues
You could have a bad ground. Next time you have the problem, hook a jumper cable from your ground on your battery to the frame or even the engine if your cables will reach. If it starts then this could be your culprit.
I have also had the nut on the power wire from solenoid to starter come of a starter before (not my porsche) which created intermittent starting problems as well.
Good luck!
Chris
Spanky is offline   Reply With Quote
