Old 11-23-2009, 07:28 AM   #1
Bladecutter
When you turn the ignition key to the start position, are you hearing any action at all from the engine bay behind you (clicking, cranking, nothing at all)?
If you are hearing nothing at all, try removing the clutch safety switch, and cleaning it, or jumpering the switch connection wires and see if you can then start the car with the shifter in neutral.
If the car starts with the wiring jumpered, then the switch is your culprit.
I think I remember someone saying once upon a time that the switch can be taken apart and cleaned. Or maybe that's just the brake switch.
BC.
Its not how fast you go, or how expensive your toys are.
Its all about how big your smile is at the end of the day that truly matters.
'98 Silver Boxster, '08 Ducati 848, '89 Honda Hawk GT, '89 Honda Pacific Coast
Bladecutter is offline   Reply With Quote
