Old 11-19-2009, 08:16 AM   #1
pschaub
burned out bulb?
This can happen when a bulb is burnt out, or if the headlamp is not making a good connection with the headlamp receptacle.
I had this same problem, fast blinking signal, when replacing my front headlamps - I had to hold the headlamp housing in place from under the wheel well to make my new lights fully connect when pushing them into place.
I would check visually to verify all lights are working as expected. Let us know what you find.
pschaub is offline   Reply With Quote
