Old 11-16-2009, 02:32 PM   #1
CJ_Boxster
Send a message via MSN to CJ_Boxster
Originally Posted by ART07154
1.need reare tires (I am planing to put a new wheels anyway)
2.need alligement(pull to the right)
3.Driver side valve cover leaking oil(moderate seepage)????
4,missing coverage shield under carriage(cosmetic).
5.slight vibration at higher speed.
6.Temperature control display not showing full number.(Expensive????)
1. No big, you usually want to buy a new matching set when buying a used car.
2. Might as well get it out of the way cause you should get one everytime you get new tires so you dont mess up your new rubber.
3. Most likely a sparkplug tube O-ring, 12 total needed to replace ALL of them on all 6 cyclindar, cost about 3 bucks an O-ring and with some forum searching you could find the repair instructions to do it yourself, novice mechanic takes about 3 hours to complete.
4. No big, your engine will cool better without it, Mine was removed when i did my front engine mount replacement and i didnt replace it and my engine ran alittle cooler for longer.
5. Have the wheels balanced and look at the RIM (not the tire) while it spins and look to see if it wobbles, if so, bent wheel. if not, your old tires can cause vibration.
6. Not a big deal, someone sells them on ebay.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
