Old 11-14-2009, 03:19 PM   #1
lardog
Porsche 986 Boxster Roll Bar Extension Kit
Porsche Brey-Krause R-3010 986 Boxster Roll Bar Extension Kit ('97-'04)
Porsche enthusiasts asked us to find a way to extend the head protection of the factory roll bar for track use. The “roll bar extension” increases the available headroom in the Boxster by an additional 1 3/4” above the factory bar.
The “roll bar extension” provides sufficient head room to permit the use of driving helmets. Protective tape keeps factory surfaces from becoming marred while careful engineering and design result in a secure fit that will not damage the car in anyway. With R-9050 Bolt-On Padding Kit for R-3010
Material:
120 wall, type 304, stainless steel tubing and mounting brackets.
Finish:
Powdercoated in durable black wrinkle-finish.
Weight:
10 lbs. 5 oz
Models:
986 Boxster only ('97-'04)
Installation:
Bar attaches to factory roll bar & seat belt mounting points.
Miscellaneous:
Bar is easy to remove and will not interfere with the soft or hard top. Bar can be stowed in trunk. Does not fit the 987.
$499.99 + shipping
lardog is offline   Reply With Quote
