Where do you connect a power bleeder? To the resevoir? That sounds like a nice tool to have...
Originally Posted by jmatta
You can have a helper depress the clutch, just as you would when bleeding brakes. I use a power bleeder and depress the clutch (held in check by a extended rod conveniently placed in the interior) and open the bleeder under pressure. The bleeder valve is a pain in the a** to get at, however.
